cold water tank
Posted: Wed Apr 09, 2008 9:08 pm
by marcpaul
hi all
just insalled a shower cubicle complete with a 2 bar pump. hot water is fine but having problems with the cold....you cant connect mains pressure to the pump so i need to put a tank in the loft but i cant get a tank that fits through the hole.can i butt 2 or 3 smaller tanks together... or can i buy a device that will reduce the cold pressure to the pump. cheers
Posted: Thu Apr 10, 2008 11:05 am
by Rico
Marc,
What kind of hot water system do you have.
Conventional, combi, unvented.
Rico
cold tank
Posted: Thu Apr 10, 2008 1:48 pm
by m d cooper
you can get a coffin tank to fit in the loft
Posted: Thu Apr 10, 2008 7:00 pm
by marcpaul
hi rico
my water system is ..a back boiler with a hot tank in the airing cupboard with a small cold tank on top that feeds the hot tank
many thanks
marc
Posted: Thu Apr 10, 2008 7:42 pm
by m d cooper
you can get a tank at screwfix,i have 1 in my loft for topping up the hot water cylinder
cold water tank reply
Posted: Thu Apr 10, 2008 8:27 pm
by marcpaul
hi rico
its a bog standard system... back boiler, hot water tank in the airing cupboard with a cold feed tank on top of it. i know i need a supply tank in the loft for the shower but i cant get a standard size tank up there. i was wandering if a pressure relief valve would do the trick if i connect the mains up to the pump, and turn the pressure down.
many thanks
marc
Posted: Fri Apr 11, 2008 11:52 am
by Rico
Marc,
What exactly is the problem with the cold. I'm assuming it is overpowering the hot.
Maybe the easiest way to sort would to check the pressure of your cold mains supply and get a matching pump for the hot.
Rico 8)
