Draining down a Combi boiler, any tips??....VENTED OR NOT???
DUDE DIY
by DUDE DIY » Tue Apr 15, 2008 6:48 am
Hi any advice is much appreciated. I have a Baxi 105 HE boiler and will shortly be needing to drain the central heating system down to reposition a few rad's as my kitchen is being extended. Ive taken a chance before and drained the system down and re filled on my own without problems before but, my questions are:
How do I know if I have a vented or unvented system?
Whats the difference?
Is there a difference when draining / re filling vented and unvented?
Is there any special precausions I should take or do?
Any additional advice?
Any advice, comments or pointers are greatly appreciated, last thing I want to do is cock my central heating system up.....the Mrs really would KILL me!
by htg engineer » Tue Apr 15, 2008 12:00 pm
The Baxi 105HE is a fairly new boiler - so will be a pressurised system (sealed).
Draining down and refilling is easy, drain from a suitable point eg a drain off or a radiator valve.
Refilling, there'll be a filling loop on or near the boiler, will probably be a silver braided hose. This is how you refill the system - open the valve and pressurise to 1.0 - 1.5 bar, vent all radiators and keep filling until the radiators are full. When all radiators are full make sure the pressure is between 1.0 and 1.5 bar and turn boiler on - it may need repressurising and radiators venting again to allow any trapped air to escape.
There shouldn't be any problems with airlocks, if you find one or two radiators aren't heating - turn off the ones that are and it will push through.
Hope this helps
DUDE DIY
by DUDE DIY » Wed Apr 16, 2008 5:33 pm
Great sound advice....much appreciated.
It is currently Sun Nov 24, 2024 3:41 pm
