Noisy Central Heating Pipes
kbrownie
by kbrownie » Fri Apr 18, 2008 12:33 pm
Just moved, the property is about 44 years old and the central heating pipes creek and groan like crazy when heating is turned on. Any solution much appreciated.
Thanx in advance
KB
by htg engineer » Fri Apr 18, 2008 8:22 pm
Normal expansion of pipes ?
Sometimes notches in joists being tight and floorboards touching pipes will cause creaking, clicking noises.
Nothing to worry about - but can be annoying.
You could lift floorboards and lag pipes, make sure they're not touching each other, widen notches in joists slightly and clip loose pipework.
Hope this helps
kbrownie
by kbrownie » Mon Apr 21, 2008 8:01 am
HI htg engineer,
Sounds like that the would be a great solution, any tips on best method of doing this work, ie tools for notches and should pipes be removed and re-installed before carrying out work. The carpets and floors are all getting renewed in the summer so coming up anyway, so should not be that bigger disruption.
KB
by htg engineer » Mon Apr 21, 2008 9:53 pm
The pipes don't need to be re-installed, unless you feel they're in poor condition or notice any suspect joints or corrosion whilst clipping and lagging.
Buy some plastic pipe clips as they allow for slight movement - if you make them too rigid something will give - normally a poor joint.
Also use screws or ringed nails as smooth nails allow for too much movement and sometimes work their way loose.
Use pipe insulation to lag anywhere where pipes touch, lagging pipes will also reduce the amaount of heat lost under the floorboards and more should reach the radiators.
As for the tools required - it depends on how much room you have to work in - the notches may be big enough and the abaove should solve alot of the noise. if not make notches larger using a saw, hammer and wood chisel.
hope this helps
kbrownie
by kbrownie » Wed Apr 23, 2008 6:31 am
Hi htg engineer,
Helps a great deal, thank you very much for your words of wisdom. It well appreciated.
Regards
KB
It is currently Thu Jan 09, 2025 9:14 am
