Toilet trouble
Posted: Sun Apr 20, 2008 12:25 am
by nic86ola
Have noticed over past couple of days that when the toilet is flushed, a short while after a loud chugging noise is heard and the toliet shakes slightly. Any ideas what the problem could be? How to fix it?
Thanks!
Posted: Sun Apr 20, 2008 7:28 am
by nitro23456
Sounds like ablockage in your waste.
Posted: Sun Apr 20, 2008 9:24 pm
by nic86ola
How do you recommend we rectify this problem? Is a plumer needed? Would it be an expensive job if so?
Posted: Sun Apr 20, 2008 9:48 pm
by rosebery
Is it the waste making the noise or the refilling process? Could be either and it's a different solution for each.
Posted: Mon Apr 21, 2008 1:10 am
by Dave From Leeds
An easy way to check for the answer to rosebery's question is to turn off your mains water then flush the toilet. If the noise doesn't occur it suggests the filling system. If noise still present then it's likely to be the waste.
Posted: Mon Apr 21, 2008 10:26 am
by nic86ola
Does anyone have any idea how to rectify the problem if due to the filling process? Is a plumber required? Thanks
