HELP finding a radiator the correct size!
nitro23456
by nitro23456 » Tue Apr 22, 2008 2:03 pm
I need a new radiator in our master bedroom - the current one is knackered and measures 600mm (H) x 640mm (W).
I cant find one this size anywhere! Does anyone know where I can get one reasonably priced - just a bog standard one thats about £30notes.
Alternatively I suppose I will have to get 600x600 with a 40mm extension or repipe, but ideally I would like a straight swap.
ALDA
by ALDA » Wed Apr 23, 2008 12:03 am
YOU COULD USE ADJUSTABLE RAD TAILS THAT WILL ALLOW YOU TO FIT THE STANDARD 600 X 600 RAD.
ONE LONG ONE ON 1- SIDE OR TWO SHORT ONES 1- EACH SIDE.
HAVE NOT SEEN RADS OF 640 WIDTH ONLY WIDTHS IN MULTIPLES OF 100.
SEARCH RADIATOR TAILS AT SCREWFIX.
chris_on_tour2002
by chris_on_tour2002 » Wed Apr 23, 2008 3:22 pm
i doubt that you will find one. might have to compromise and use the adjustable valves. or drain down and redo the f&r pipes.
It is currently Thu Jan 09, 2025 2:00 pm
