Couple of problems need help
armytouch
by armytouch » Tue Apr 22, 2008 2:19 pm
Hi hope you can give me some advice,firstly one new radiator only heats up at te bottom the rest is just warm however there is no bleed off valve,how do i get the top to heat up?
Secondly the downstairs toilet starts sqealing very load after it been flushed,while it filling only?
nitro23456
by nitro23456 » Tue Apr 22, 2008 6:22 pm
toilet is a problem with your inlet valve/ball valve. probably just needs a new washer but it is easier and nearly as cheap to change the while thing.
Radiator - must be a bleed nipple somewhere - back/side? sometimes they are flat head screw shaped.
It is currently Thu Jan 09, 2025 8:42 am
