saniplus discharge
Posted: Mon May 26, 2008 5:29 pm
hi all a follow up from my previous post about the saniplus marcerater just read in the instructions that for every elbow due to friction you shud reduce 50cm of the vertical height i av 4 elbows in total due to akward position of soil stack cud that be stopping the pump from discarging the waste and if so cud i cure that problem by redoing discharge in a bigger diameter pipe or wud that make no difference cheers guys bazza . ps discharge at moment is 22mm therefor thinking of increasing to 32mm max height for vertical rise is 5mtrs on saniplus mines at 4mtrs but has those elbows attached i hav 1 elbows on the vertical pipework and 3 more on the horizontal pipework hope this makes sense thanx again bazza
