plumbing. expansion pipe
Posted: Fri May 04, 2007 3:23 pm
by rhodrigruffydd
the expansion pipe in my feed and expansion tank is overflowing when my pump is at 2 but not when its at 1. the problem is when the pumps at 1 the downstairs radiators do not warm enough. they do at 2 but back to the problem, the hot water then comes out of the expansion pipe. this only happens with the hot water and not the central heating. the three port valve seems to be working fine and the expansion pipe and the cold feed is in the correct place. help!
Re: plumbing. expansion pipe
Posted: Sat May 05, 2007 11:12 pm
by dave p
There could be a build up of sludge on the walls of your pipes. Or sometimes there is a gate valve on the return from the cylinder which could be restricting the flow too much. Have you got an auto by-pass fitted. Also you can change your central heating pump to one which slows down when pressure in the system starts to increase.
Posted: Tue May 08, 2007 7:02 am
by jondeau
It's a fairly good bet that the design of the system is at fault here.
You should get this sorted out quickly as water flowing from the expansion pipe will be re-aerating itself as it does so.
This extra oxygen being picked by the water will quickly rust out your radiators.
