Replacing Radiators
debbie2010
Replacing Radiators
by debbie2010 » Mon Aug 18, 2008 1:44 pm
Ive just moved into a house were i want to change all radiators and valves cos all the old ones look worn. Ive took measurements of the old bathroom rad and for it to be 640mm but the biggest replacement i can find has a width of 620mm is there anyway to bridge the gap i dont really want t put the old one back on it will look out of place with the refurbof the house.
pb1
Re: Replacing Radiators
by pb1 » Mon Aug 18, 2008 8:27 pm
[quote="debbie2010"]Ive just moved into a house were i want to change all radiators and valves cos all the old ones look worn. Ive took measurements of the old bathroom rad and for it to be 640mm but the biggest replacement i can find has a width of 620mm is there anyway to bridge the gap i dont really want t put the old one back on it will look out of place with the refurbof the house.[/quote]
hi debbie,if you dont fancy redoing the pipe work you can buy radiator extensions in various sizes that will make up the size difference.if you cant find an extension to match you can screw a 1'2 " male iron into the rad and go to the valve with copper. hope this helps good luck.
by htg engineer » Mon Aug 18, 2008 9:37 pm
There's normally a way of bridging the gas, you can buy radiator tail extensions
http://www.screwfix.com/search.do;jsess ... iator+tail
Sometimes fitting a radiator valve that incorporates a drain off - is enough to take up the gap.
htg
It is currently Mon Dec 23, 2024 2:15 am
