Combi turns on for no reason
6 posts   •   Page 1 of 1
deguerre
by deguerre » Mon Sep 01, 2008 4:16 pm
Hi, I have a combination boiler, sometimes it will turn its self on for a short time for no apparent reason, (its not a pre heating boiler BTW), no taps running, CH not on. It normally happens at night. Any ideas why it would do this?
by htg engineer » Mon Sep 01, 2008 9:26 pm
Firstlt check you're not missing something simple like programmer set to timed mode ?
Could be a faulty sensor bringing the boiler on as the majority now have a frost stat. If the temperature drops the boiler will bring the heating on to prevent the pipes etc from freezing.
htg
deguerre
by deguerre » Mon Sep 01, 2008 10:13 pm
Hi thanks for the reply, the timer seems to be set correctly, I don't think it has been cold enough recently for the frost sensor to have come on, what type of sensor could be causing it?
I have a friend who is a gas engineer, but he doesn't have a clue what would cause it, maybe you could point him in the right direction?
Thanks.
by htg engineer » Tue Sep 02, 2008 11:41 am
Make and model of boiler ?
Sorry didn't explain properly. I'm not saying it has been cold enough - i'm saying the sensor/frost stat may be faulty.
htg
chris_on_tour2002
by chris_on_tour2002 » Thu Sep 04, 2008 10:19 am
you need a boiler engineer. there is clearly a fault with a sensor somewhere. could be one of a number of things that have already been stated, but without actually looking at it, it's impossible to say.
deguerre
by deguerre » Fri Sep 05, 2008 5:27 pm
Hi sorry for not replying I've been busy lately, my british gas friend checked the frost sensor and said he thinks thats the problem, he has swapped it for a new one now so I will have to wait and see if the problem goes away.
Thanks for all your help.
It is currently Mon Jan 27, 2025 10:08 am
