How to connect 3/4" pipe to 22mm pipe
Posted: Mon Sep 15, 2008 9:47 am
by jnr diy
"Hello" I want to replace my old bathroom suite but the pipes are old 3/4",how do i connect old 3/4" pipes to new 22 mm pipes,the only fitting i can see is (3/4" to 22 mm lead to copper) would this be ok to use.Please help.
Posted: Mon Sep 15, 2008 10:10 am
22mm compression fittings will work. Or you can buy imperila to metric connectors - ask at you local plumbers merchants.
htg
Posted: Mon Sep 15, 2008 5:06 pm
by plumbbob
You can buy 3/4" olives to enable 22mm compression fittings to be used.
