Bathroom Refit
Posted: Thu Sep 18, 2008 10:02 pm
Hi.
Our bathroom is a bit outdated and we have decided to install new units.
current setup:
basin and bath cold taps are mains fed
basin and bath hot taps are tank fed
The cold water tank is in the loft
the hot water tank is on the first floor adjacent to the bathroom.
we want to fit a shower bath and based on the articles here, in order to get a sufficient pressure coming out of the shower head, we need to install a shower pump.
Is it possible to mains fed the cold inlet of a shower pump?
What type of shower pump do we need and can anyone recommend a good shower pump that we can use? Something that is not so expensive but still sturdy.
Where is the best place to site the shower pump?
On a totally different subject, when we flush the toilet, there is almost always a loud vibrating sound that comes from the pipes. The toilet cistern is mains fed but the pipe goes to the loft first and then drops from the ceiling to the cistern. Is there a way to reduce the vibrations if not eliminate them?
Thanks for reading and hopefully you can advice me on the points noted above.
current setup:
