washing machine waste
greengrass
by greengrass » Wed May 09, 2007 2:01 am
I am shifting the washing machine from the kitchen to a utility room that funny enough has no drainage facilities.
Knowing most appliances have 1.50mm wastes, could a back flow be caused using the smaller 1.25.
Reason for asking are two obstacles. 1. a surface water drain pipe which will take the 1.25 behind it. 2.'Er who will be obeyed :cry: has asked if 1.25 can be used it will show less' I sighed heavily as I explained as both pipes are white either will be visual you silly moo, she slung I ducked and the saucepan hit the wall.
The other alternative is to start 1.50 internally and on reaching outside reduce to 1.25 pipe on the outside wall.
thedoctor
by thedoctor » Sat May 12, 2007 10:17 am
Not a good idea to reduce the waste pipe either inside or out Greengrass, the amount of water and the flow rate are not easily coped with by a smaller diameter.
Arnak
Washing machine waste.
by Arnak » Sat May 12, 2007 11:34 am
Why not box it in afterwards then tile the boxing.
Tell her who must be obeyed that it will be decorative and make a nice low shelf.
Now all you've go to do is fix the dent in the wall made by the saucepan. :lol:
Arnak
greengrass
Re: washing machine waste
by greengrass » Sat May 12, 2007 3:27 pm
[quote="greengrass"]I am shifting the washing machine from the kitchen to a utility room that funny enough has no drainage facilities.
The other alternative is to start 1.50 internally and on reaching outside reduce to 1.25 pipe on the outside wall.[/quote]
THANKS BOTH OF YOU
It is currently Sun Dec 22, 2024 11:25 pm
