Sealing New Rad Valve pipe irons
kbrownie
by kbrownie » Sun Oct 12, 2008 4:16 pm
Hi all,
Installing new rads, not bad at pipe work bends and soldering. But never put new rads on from start (not a plumber).
My question is; New valves, the irons that screws in to bottom of rads either side that connect to valves/thermal controls, It seems that these have a slight taper on, what is best way to seal the joint is it using a compound or ptfe tape or is there something else? Any other tips appreciated too!
KB
plumbbob
by plumbbob » Mon Oct 13, 2008 12:08 am
Wind about 8 - 10 turns of ptfe tape around each thread. This should be sufficient to give a good seal.
Steve the gas
by Steve the gas » Mon Oct 13, 2008 5:23 am
Yep PTFE tape or paste will do it
kbrownie
by kbrownie » Mon Oct 13, 2008 5:20 pm
Steve the gas and plumbbob
That's great, thank you both for help
KB
It is currently Sat Jan 11, 2025 1:48 am
