Speed fit connectors
Posted: Mon Oct 13, 2008 10:18 am
Hi there,
Just fitted a new bath at the weekend and used speed fit connectors to connect bath taps to hot and cold feed.
Everything looks good with no leaks but i noticed the hot push fit connection moves up and own a little when you turn the hot tap on and off, cold is fine and does not move.
Cold comes from CW tank in loft and hot is supplied from a combi located downstairs.
Is this normal, its not leaking and i have pushed id down firmly again?
Push fit is going to 22mm copper pipe.
Newps
Newps
