low hot water pressure
jimmy 68
by jimmy 68 » Mon Oct 13, 2008 8:59 pm
new kitchen recently fitted. new hot water tap flow is low. it is a gravity fed system but previous h.w. tap worked o.k. any suggestions?
chris_on_tour2002
by chris_on_tour2002 » Mon Oct 13, 2008 11:18 pm
check the specification of the tap. sounds like the new one is designed for use on a high pressure system. the cold to the kitchen tap is always, or should be at least, mains fed so you would not expect low pressure on the cold side.
if it is then its no good, you would need change for one suitable for low pressure.
It is currently Sat Jan 11, 2025 4:53 am
