Toilet flush sounds like QE2 arriving at Southampton
Posted: Wed Oct 15, 2008 12:29 pm
by mao1
When we flush the loo upstairs and downstairs the pipes vibrate very loudly, and sound like the QE2 or similar ocean liner.
It doesn't sound like water hammer unless it is a very high frequency version.
The house is semi detached and I have noticed next door has the same problem!
Any ideas anyone? :roll:
________
buy air one vaporizer
Posted: Wed Oct 15, 2008 9:10 pm
by nitro23456
Are the pipes clipped properly? is the toilet cistern bottom feed?
Posted: Thu Oct 16, 2008 6:12 pm
by mao1
Hi, thanks for reply.
When you say clipped, do you mean are they secured properly?
Will get back to you on top or bottom feed
________
Mercedes-Benz W163 specifications
Posted: Fri Oct 17, 2008 11:00 am
by nitro23456
Hard to advise without seeing and hearing for myself. But things to check....
-pipes secured properly
-Is it mains water fed or tank fed...try winding the stopcock back half a turn... it shouldnt be open fully open and may be a pressure problem.
-bottom fed and side fed systems reduce the chances of water hammer (especially bottom)
actually having just reread your post and seeing its happening in both toilets you have and next door, I would imagine its related to water pressure. try turning the water off altogether and then flushing with the water off.... see if that makes a difference to rule it out..... then turn it back on and see if it happens on refilling. wind the stopcock back a bit.
Posted: Fri Oct 17, 2008 1:40 pm
by mao1
Upstairs loo is top feed, downstairs is bottom (or other way round can't remember now)
They both make the noise.
Can't see most of pipe work as under floor boards etc.
________
buy herbalaire
Posted: Mon Oct 20, 2008 3:45 pm
by dedzed
It sounds like a rubber seal in one of the stopcocks is vibrating as the water passes though it (same principle as the reed in a saxophone)
the stopcock needs a new valve seal and/or is not fully open...or the toilets.... if its the old float valve systems they are very prone to it.... just change the diaphram valve.
Posted: Tue Oct 21, 2008 10:34 am
by mao1
Many thanks, I'll check that out
________
E83
