Mixer shower...
Posted: Tue Oct 28, 2008 9:15 pm
by inch high
I currently decorating my bathroom and I am wondering whether to fit a mixer shower after seing them in B&Q today.
At the moment, I have one of those showers that you push onto the taps.
I have a combi-boiler (I think its high pressure - its in the kitchen so I assume if it was low pressure it would struggle to get the water out fast upstairs?).
Would it just be a case of running a couple of pipes off the current hot and cold taps onto the shower?
Inchy
Posted: Fri Oct 31, 2008 8:02 am
by ukbill
you could fit a bath shower mixer i reckon thats the cheapest way
Posted: Fri Oct 31, 2008 9:12 pm
by plumbbob
Combi boilers are high pressure and a mixer shower should work great providing you have good mains water connection. These type of showers can be connected directly to the feeds under the bath.
Posted: Thu Nov 06, 2008 5:03 pm
by inch high
[quote="plumbbob"]Combi boilers are high pressure and a mixer shower should work great providing you have good mains water connection. These type of showers can be connected directly to the feeds under the bath.[/quote]
Cheers Plumbbob
Posted: Thu Nov 06, 2008 8:16 pm
by AdamsHeating
Quick answer: Yes.
If you are using a shower head that is loose, make sure you add double check valves in line on the pipe work to the shower somewhere to keep up to date with the current water regs regarding water contamination. If you are installing a rigid shower (one that is permanently fixed) then you don’t need to add the check valves.
Oh and for servicing convenience, I would suggest adding a couple of isolation valves under the bath to make servicing a bit easier.
All of those things will only cost a couple of quid.
Hope this helps,
AH.
