Quadrant shower tray installation
Posted: Sat Nov 01, 2008 2:46 pm
by carruthers
Does anyone have the answer to the finishing of the 'skirting' finish to a quadrant stone cast shower tray that has to be raised to accommodate the waste. The floor is concrete. I can't seem to find anything in the DIY sheds, that is made for the job.
Any suggestions? Please
Posted: Sat Nov 01, 2008 7:51 pm
by forrest38
hi
I work in a plumbers merchants. All you need is a flexible plinth. That's what it's called. Just have to go to any plumbers merchants. Might need ordered in depending on size.
Posted: Sat Nov 01, 2008 8:10 pm
by Skids
Hi carruthers
Go to one of those ‘guttering’ or ‘plastic cladding’ outlets, they usually have a wide choice of strips that will suit.
Regards
Skids
Posted: Sat Nov 01, 2008 10:40 pm
by bobplum
hi
is it possible to place hardboard between floor and shower tray set back a few mm and then tile over with mosaics tiles
bob
Shower tray
Posted: Mon Nov 03, 2008 1:36 pm
by carruthers
Many thanks for the responses. I hadn't thought of the plumbers merchants :oops:
Curruthers
Posted: Mon Nov 03, 2008 7:13 pm
by chris_on_tour2002
check with the supplier of your tray - some manufacturers will make them, it might be possible that you can buy one for your particular model.
Posted: Mon Nov 03, 2008 10:45 pm
by plumbbob
Go with Skids option of UPVC soffit board which is only a few quid. The plastic trims are identical in colour and texture to shower trays.
