General plumbing
Posted: Tue May 30, 2006 5:13 pm
by thedoctor
To post a question for a Diy Doctor tradesman or your fellow users, to answer please click on “New Topicâ€
Posted: Fri Mar 09, 2007 2:09 pm
by tapper
How do I turn off the hot water when I want to change the washer in the tap in a system which has no hot water cylinder?
Posted: Wed Mar 14, 2007 9:09 pm
by KEVANS02
i guess your how water is heated via a combi boiler if this is the case then if you turn the mains cold water stoptap off then this will stop both hot and cold water to taps
hope this helps , kev
Posted: Fri Mar 16, 2007 2:00 pm
by thedoctor
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE
www.diydoctor.org.uk/projects.htm
