boiling Water from Tank
Posted: Fri Dec 12, 2008 5:24 pm
Have cylinder tank which will not lower temp. I am not using immersion heater, Should I try This. Have changed strap on cylinder stat and taken it down to lowest setting. Still very hot, kids cannot use hot tap due to the heat. Tank in loft still cold and no problem. Have had this problem for the two years we have been here. the children are of the age to wash hands but cannot due to heat. Am i missing something. Please help. many thanks john
could it be diverter valve and if so how will I know. has diverter valve got thermostat.john
Have swiched off supply to heating and water and moved both diverter valves over and both moved back to halfway.Also can the diverter valves be put to manual to sort out this temporarily
