INSINKERATOR+1.5 BOWL + WASTE
Posted: Tue Dec 23, 2008 2:03 pm
by Clyde
I'm having diffculty trying to work out how to incorporate an insinkerator+1.5 bowl then connect to waste.
Has anyone done this before? Please could you advise on the parts I need, better still, send me a picture, I have one bowl connected up and the insinkerator plug all fitted to the sink, but now I need to include the insinkerator then finally connect to the waste. (currently only have one bowl connected to the waste just so I can use the sink!
I was thinking of purchasing two HepVo valves and some flexible pipe???
would this do it plus some kind of coupling valve?
Thanks,
Clyde.
Posted: Tue Dec 23, 2008 6:37 pm
Clyde,
Get some pipe (make sure this is the right size to fit the insinkerator) and ring-seal fittings. Try to connect the pipe from the insinkerator as far as possible away from the standard sink trap. The advantage with ring-seal fittings is that you can always modify the pipe layout.
Posted: Wed Dec 24, 2008 7:19 am
by Clyde
Thanks Stoneyboy, I spent nearly an hour in DIY store last night, I've cracked it. I've put a solvent weld t-piece on waste then flexi type ubend from insinkerator to one t-piece fitting (solvent weld) then the exsisting s-trap from sink to other t-piece (via self weld flexi).
Took me weeks to work this one out!
Posted: Wed Dec 24, 2008 5:04 pm
by Steve the gas
No, that was a day lol
