Baxi Solo WM 50/4RS
Posted: Wed Dec 31, 2008 12:03 am
by bunts
Pilot lites but goes out when turn knob to next position. Thermostat trip switch has been reset but still does not resolve the problem. For information this started after I removed and replaced two radiators to clean them through and I completely drained the whole system to do this. Before trying to restart my boiler, the heating system was refilled and air bleeded from all radiators.
Posted: Thu Jan 01, 2009 7:01 am
by Steve the gas
Hi Bunts,
You seem to be describing a permanent pilot that will not stay lit?
If so , the thermocouple has failed,approx £6 + fitting
Hth
Pilot not staying on
Posted: Sat Jan 03, 2009 3:07 pm
by bunts
Thanks for advice. Thermocouple changed but still not working. Engineer called and replaced the boiler thermostat which did the trick.
Posted: Thu Jan 29, 2009 12:34 pm
by TheDoctor5
