Radial Wiring in a domestic property.
Posted: Fri Jan 02, 2009 4:10 pm
by Jhdj13
I plan to extend the number of power points in a domestic property. (The planned extensions are within the "non-notifiable" guidelines of part P of the building regulations).
However, I've found that the property is wired with radial circuits, rather than a ring main which I'm used to. It has four circuits: one 30 amp direct to the oven, another 30 amp power circuit and two 5 amp light circuits.
My question is, "Is there any way of identifying whether a particular electrical power socket with just one incoming wire is located at the end of a radially wired run or is just a wired spur from another power socket? In both cases the power socket in question has just one incoming wire.
Advice or pointers would be welcomed, experienced or not.
Email: Click here to Email
Posted: Sun Jan 04, 2009 11:29 am
Jhdj13,
ericmark posted a really useful publication from BSI which spells out radial circuit arrangements really clearly. I can't find the post but if you google "BS7671:2008 corrigendum" you should find it.
Posted: Sun Jan 04, 2009 1:45 pm
May be better posting in electrical forum
Posted: Thu Jan 29, 2009 12:35 pm
by TheDoctor5
