TWO RADIATORS OFF SAME FEED
Posted: Mon Jan 12, 2009 8:19 pm
by major
CAN I CONNECT TWO RADIATORS TOGETHER BY CONNECTING THE SECOND RAD INTO THE 1ST RAD THANK YOU FOR YOUR TIME
Posted: Tue Jan 13, 2009 1:44 pm
by C23kW
i suppose you could but in my opinin, you wouldnt get very good performance from them bcos ther'll b two rads running from same pipework. It would b farely easy jst to extend the pipework.
Posted: Tue Jan 13, 2009 4:57 pm
Size of pipes ? if smaller than 15mm - NO.
If 15mm then it'll work but would be better having 2 x flow and 2 x return.
htg
thank you very much
Posted: Tue Jan 13, 2009 6:24 pm
by major
[quote="C23kW"]i suppose you could but in my opinin, you wouldnt get very good performance from them bcos ther'll b two rads running from same pipework. It would b farely easy jst to extend the pipework.[/quote]
8mm microbore so I guess the answer is no. thank you
Posted: Tue Jan 13, 2009 6:26 pm
by major
[quote="htg engineer"]Size of pipes ? if smaller than 15mm - NO.
htg[/quote]
Posted: Thu Jan 29, 2009 1:35 pm
by TheDoctor5
