boiler problem
Posted: Mon Jan 19, 2009 12:58 pm
by rfroud
My bosh Worcester combi boiler is showing that there is no pressure in the system.
I have topped it up several times and the pressure goes down within a minute or two.
There is no sign of a leak.
I haven’t used this advice forum before; I hope some one can give me some advice.
Robert
[/quote][/u][/i][/b]
Posted: Tue Jan 20, 2009 6:14 am
by Steve the gas
Hi Robert,
Well the water is going somewhere.
Check the blow off pipe outside just under your boiler but outside (PRV)
It may be dumping the water from there.
If so PRV needs changing.
If your skills are up to it check the EX Vessel for water in it, it should be air from the car tyre type (Schrader) valve.
Hth
Posted: Thu Jan 29, 2009 2:15 pm
by TheDoctor5
