Hissing noise from pipes
Posted: Sun Jan 25, 2009 11:12 am
by malpractice
There is a hissing noise similar to the noise when a toilet is re-filling coming from the pipes. The toilets are ok and the noise persists even when everything is turned off and the stop cock is turned off. Any ideas.
Posted: Sun Jan 25, 2009 7:45 pm
by Stelf
There is a strong chance you have a leak in the underground water main before it enters your property. Your water company will almost certainly investigate for you if you ask but you may have to hire your own plumber to fix the problem.
Best wishes
Posted: Thu Jan 29, 2009 2:27 pm
by TheDoctor5
