overflow of overhead water tank
Posted: Wed Feb 04, 2009 9:25 am
by cyndel
my small water tank is constantly dripping though i have changed the vavles twice . more over there is an over flow ouy=tside of the building near the roof . please help
Posted: Wed Feb 04, 2009 3:45 pm
by gooner4life
When you say small water tank do you mean the f and e tank? The smaller of the two in the roof?? And is the water coming out of the overflow pipe outside?
Posted: Wed Feb 04, 2009 6:40 pm
by cyndel
yes, its the smaller tank in the roof
Posted: Wed Feb 04, 2009 7:35 pm
by Stelf
Have you checked it is not just something simple like bending the float arm down just a touch to lower the water level? Just wondered.
Best wishes
Posted: Thu Feb 05, 2009 10:29 am
by gooner4life
I would suggest the above too, the valve might just need adjusting - hence letting the water level get as high as the overflow.
Posted: Sat Feb 07, 2009 7:50 am
by nitro23456
if not the above, anther possibility os the system is pumping over.... does this happen only when the heating is on?
Posted: Sat Feb 07, 2009 7:51 am
by nitro23456
You need to get up there and see where this extra water is coming from.... more info needed.
