No hot water out of kitchen tap
Posted: Thu Mar 19, 2009 2:28 pm
by nrg1977
Hello,
my mixer tap in my kitchen doesn't run hot water. I have it turned to the hot water side but only cold water runs out. However my boiler is heating up water fine as the taps in my bathroom run hot water.
Any ideas? I think I have a combi boiler.
Posted: Thu Mar 19, 2009 10:18 pm
by rosebery
What happens when you turn it to the cold water side?
Is it a new tap?
Posted: Fri Mar 20, 2009 1:47 pm
by C23kW
problem with the tap, just change the tap. get them cheap enough now
cheeres
Posted: Fri Mar 20, 2009 6:16 pm
by nrg1977
Cold water side is just cold water. It works exactly as before just the water coming out the hot water side is always cold.
Not a new tap, not an hold tap either. Nothing done recently central heating or hot water wise.
Just a mystery!
Posted: Fri Mar 20, 2009 9:43 pm
by rosebery
Is it a monobloc with a thermostatic cartridge?
Sounds like the cartridge may have failed and its not letting any hot through - blocked filter?
Posted: Sat Mar 21, 2009 11:13 am
by nrg1977
That sounds a bit fancy. It really is just a simple mixer tap.
Is there any way I can unblock the filter rather than getting someone out to replace the tap?
Thanks again
Posted: Sun Mar 22, 2009 8:54 pm
by rosebery
Then I'm stumped at this distance frankly. If its a simple mixer tap then when you open the hot side you should get hot water not cold. There probably wont be any filters on a simple mixer.
It would probably be as clear as daylight if I could see it. LoL.
Suggest you get yourself a plumber.
