Which shower to buy?
Posted: Sat Mar 28, 2009 10:38 pm
by richhe
I have a problem. I have a NewTeam NT968 Thermostatic Valve, which requires 13.5 cm inbetween the cold and hot water inlets. Went looking for a replacement shower today (as my old one has packed in- can only get cold water), but all the ones I found have about 15.5cm inbetween inlets (was looking mainly at Triton's). Access to the pipes behind the shower wall is tricky. Can anyone advise on which mixer showers I would be able to buy to fit my current pipes?
Rich
Posted: Sun Mar 29, 2009 11:41 pm
by plumbbob
You are going to be very lucky to find another make of shower with anything other than either the old 6" centres or the new 150mm.
I suggest you visit the New Team site to see if they offer a replacement.
Certainly manufacturers such as Triton and Mira and other leading brands only have, to the best of my knowledge, the 150mm centres.
Posted: Mon Mar 30, 2009 12:10 am
by rosebery
It sounds as though the cartridge has either failed or its gummed up with scale.
Rather than replacing the whole thing it would seem a better idea to remove the cartirdge and clean it. If it still doesn't work properly then replace the cartridge. Save a lot of hassle.
Also whilst you have the cartridge out check that the filters are not blocked.
HTH
Posted: Thu Apr 09, 2009 3:50 pm
by Deborah
Hi There I found a thermostatic valve by Googling " mytub.co.uk" at a good price.
