adding a sink waste using a strap on soil boss
russellfl
by russellfl » Mon Mar 30, 2009 8:07 pm
Can anyone tell me how to fit a strap on boss to a soil pipe and how does the 32mm waste pipe connect into it? do I have to use a solvent weld or can you get a push fit connection?
plumbbob
by plumbbob » Tue Mar 31, 2009 9:38 am
First, you cut a (usually) 57mm diameter hole in the stack and glue the strap on securely.
Then a rubber boss pushes in allowing the waste pipe to connect to the strap.
http://www.awin1.com/awclick.php?mid=12 ... rods/89174
(There are different manufacturers of pipe and the bosses are different so make sure you use the same supplier.)
It is currently Sun Dec 22, 2024 11:31 am
