Vibrating 15mm pipe feeding the cold water tank?
BriJo
by BriJo » Sun Apr 19, 2009 9:41 am
I have a 15mm copper pipe feeding a cold water tank which is very noisy after flushing the wc and using the shower.
I have clipped the pipe which vibrated alarmingly, this has helped but the noise still persists. I wonder if it may have something to do with the float valve in the cold water tank?
plumbbob
by plumbbob » Sun Apr 19, 2009 11:26 am
It is definitely the valve. As the valve wears, and the rubber seal becomes hard, the flow of water causes the mechanism to oscillate as you describe. It is a common problem. You have to put up with it, or replace the whole ball valve.
by htg engineer » Sun Apr 19, 2009 7:30 pm
Replace the valve.
htg
rosebery
by rosebery » Sun Apr 19, 2009 7:50 pm
Yes replacing the entire valve is cheaper than messing about trying to repair the current one.
It is currently Sat Dec 28, 2024 8:46 pm
