CombiBoiler / thermostatic mixer hot bath OK but not shower
Jimbo Burtonia
by Jimbo Burtonia » Tue Jun 23, 2009 5:21 pm
Newly installed bathroom uses Cherish Bath Shower Mixer £216 as supplied by Wickes. The thermostatic control works fine running a bath but when switching to shower closes down the boiler and runs cold after a short period. I should mention that the combi boiler is a brand new (expensive!) British Gas installation with brand new pipework throughout bungalow (nothing in the roof or gravity fed. The boiler is situated a couple of feet away in the next room.
I'm wondering whether the Mixer is faulty (the twist tap just goes round and round without a fully open 'stop' point) or whether the problem lies in the increased pressure needed to supply the shower head 'backing up' in some way. How could this be - surely the hot and cold, both coming straight off the mains will be at the same(ish) pressure.
If any of you professionals out there can shed some light on this problem I'd be very grateful to hear your views.
Thanks in advance.
by htg engineer » Thu Jun 25, 2009 7:53 pm
'the combi boiler is a brand new (expensive!) British Gas installation'
The boiler probably wasn't that expensive - probably just the labour.
What's the boiler make and model, we will need this info to offer help really - all boilers work differently - is the DHW demand light illuminated on the boiler the whole time the shower is running ?
htg
Jimbo Burtonia
by Jimbo Burtonia » Fri Jun 26, 2009 12:09 pm
It's a Worcester Bosch Greenstar 30: I take your point about BG's expensive labour but I went with them as I needed their all inclusive removal of all legacy pipework, tanks, immersion cupboard, old pipework and old radiators giving a nothing-in-the-roof setup.
The boiler demand light goes out after a couple of minutes sometimes sooner, but only happens when switched from bath to shower use. Bath and other mixer taps work as they should.
plumbbob
by plumbbob » Sat Jun 27, 2009 12:23 am
To be honest, I would head straight for the shower mixer problem. The boiler is shutting down because the shower is not calling for hot water for some reason Is that not logical?
I assume the boiler supplies hot water on demand to all other outlets without a problem?
Jimbo Burtonia
by Jimbo Burtonia » Wed Jul 01, 2009 4:30 pm
Yeah, you're right...I've had the HWCH system checked out by BG and it's all tip top. It's back to Wickes with the mixer as all other outlets work fine.
Thanks for responses.
It is currently Sat Dec 28, 2024 9:33 pm
