Trying to identify what boiler we have and how to work it !
Posted: Thu Aug 06, 2009 11:02 am
My son just moved into a rented flat and neither him nor I have any knowledge of boilers or any heating systems for that matter, therefore I am looking for some help, please as he has problems in identifying what the 2 switches on the wall do and how the boiler should be set to have hot water which at the moment works via a guessing type of approach, I'm afraid.
I've been trying to research what type of boiler he has but haven't got too far as it sounds quite complicated but I can tell you that the set up as we know it at this point is the following: a large big cylinder on some sort of support in the airing cupboard (the make is Gatmet or something like that) which has a clock dial type thing at the front with a thermometer type display which shows temperatures from 20 to 120 (degrees Celsius, I believe). this boiler has some connections with some pipes but couldn't explain how. The only other thing I can tell you is that there are 2 switches on the wall in the same airing cupboard which seem to relate to this setup, one has Boost written against it and the on/off button and the other one has an E written against it and it can be turned on or off.
I apologise for the very basic way I am describing this, but I don't know any better in this subject, I'm afraid ... :(
My questions to you are:
1. what do we need to press/activate and what temperature do we have to set the round dial on the boiler to have hot water (I can't see a thermostat anywhere to set the time of day or such, therefore I presume this must be an older type boiler)
2. what type of boiler is this (we can't get into the loft, my son just moved in and doesn't want to 'disturb' the setup there and the loft door seems to be blocked in some way so can't say if there are any tanks in the loft and the estate agents were less than useful at this stage)
3. does this boiler set up mean that the boiler needs to be at a certain temperature all day in order to have hot water at any time ?
Also, I looked at the radiators in the rooms and they are very wide, big things with some switch on top but they seem to be connected with a pipe, so I presume they are also part of the system and working the boiler appropriately will be important for when it gets colder in order to have heating in the house. How do these relate to everything and what would he have to do to keep constant warmth in the flat, please ?
Too many questions, I know, but we have no one else to ask unless we go back to the estate agents and ask for a proper explanation of the system and if they can't do it they'll have to send the owner out to do it, otherwise it is just impossible to 'guess' when you know nothing about this.
Thank you so much for your help with this.
Aurelia
Aurelia
