Can I turn off electric water heater?
s4room
by s4room » Thu Aug 13, 2009 12:00 am
I just moved into a flat. At old address, gas boiler was used. Now, everything in the flat uses electricity. I'm new to electric water heater and do not really understand how it works. I find out that the electric water heater is powered on 24/7. Can I turn off the heater when I do not use it, and switch it on when I'm about to use it, e.g. shower?
There are two wall mounted convector panel heaters in the flat. Thus, I think the water heater only provides hot supply for shower and taps.
The model of water heater in my flat is "OSO 20 RD125 (DIRECT model)".
Google "osohotwater.com/uk/produc...l_details.html"
The specifications of the water heater is:
http://img.photobucket.com/albums/v6...d125_specs.jpg
There are several AC main power switches around the heater:
http://img.photobucket.com/albums/v6...s_switches.jpg
There is one switch labelled as "Isolator". I'm not sure if it is for the heater. If it's, please advise its function in the heating system.
http://img.photobucket.com/albums/v6...5_ISOLATOR.jpg
Close-up view of switches. There are four red leds on the TIMER panel, and all of them are ON. What does it mean?
http://img.photobucket.com/albums/v6...d125_timer.jpg
The hot water output pipe is insulated.
http://img.photobucket.com/albums/v6...ateroutput.jpg
[Questions]
[1] Should I turn it off if I use the water heater model as described above?
[2] Should I turn both (4) and (5) switches off, or only either of them?
[3] What is the function of the ISOLATOR?
[4] Any idea how does the timer work?
[5] Is it safe to switch it off during winter? Will this cause damage to the water pipe?
chris_on_tour2002
by chris_on_tour2002 » Fri Aug 14, 2009 4:03 pm
don't seem to be able to look at your pics - can you use an alternative website to post them on?
It is currently Sun Dec 29, 2024 1:38 pm
