Stuart Turner Pump making a major racket
Posted: Sun Oct 11, 2009 11:52 am
Guys,
I have just fitted a Stuart Turner Showermate 1.5 bar Twin, and it is making a seriously horrible racket.
I phoned the ST help desk and I was not helped very much.
I told them the supply was in 15mm pipe and they immediately said it was water starvation. But that is not likely, first the supply pipes are under good pressure, the heght of water above the pump is nearly 4 metres and second, before this pump I used a Wickes 1.2 bar and it had no trouble at all.
I worried that it might be the shower valve, so I fitted a new valve(!) and it made no difference.
I took the sides off the pump to see if there was anything stuck inside and there wasn't.
So, I am stuck. I worry that the pump may have been faulty right out of the box, but of course ST did not want to talk about that.
The noise from the pump is horrible, it must be three times louder than the old Wickes pump; it is definitely not right, but I don't know what to do next.
Oh, the tone of the noise chages as I turn from hot to cold. The flow of water is nothing special either, I got more with the wICKES 1.2. Groan.
An good ideas?
Regards
Adrian
An good ideas?
Regards
Adrian
