TOILET FLUSH BREAKAGE/REPLACEMENT
Posted: Mon Oct 12, 2009 11:44 am
by seeker
i have a close coupled toilet with a push button flush, the internal push mechanism has broken and the standard replacement unit will not fit due to the operating buttons unit in the lid being much larger than usual and oval shaped, the broken button inside the cistern is on a vertical tube about 30 cms long, which i can remove by twisting anticlockwise and lifting out but i cannot find a maker or supplier to replace the broken part, any help will be greatly appreciated
Posted: Tue Oct 13, 2009 9:28 pm
by steve the plumber
Try the following:
Elecmec Ltd‎ - 480 Honeypot Ln, Stanmore, *******, HA7 1JR‎ - 020 83570072‎
They have a plumbers attached and you will get the unit you want from there.
TOILET FLUSH REPAIR/REPLACEMENT
Posted: Sun Oct 18, 2009 11:13 am
by seeker
Thanks SteveThe Plumber, the job is now sorted. Thanks again! Seeker
