Toilet Blockage
Posted: Wed Jun 06, 2007 1:41 pm
by chrisr
A plastic toilet block holder that normally hangs on the rim of the toilet has fallen into the bowl and has become stuck somewhere beyond the U bend. I have managed to clear the backup of toilet tissue etc by using a plunger but it seems that the plastic holder is still stuck somewhere as new stuff is backing up again. Is it better to remove the pan (close coupled system) and how easy is this?
Posted: Thu Jun 07, 2007 8:08 am
removing a close coupled toilet should be easy enough as long as it hasn't been siliconed or had floor tiles cut round the pan.
Normally 2 screws just under the cistern lid holding it to the wall, and 2 screws in the pan holding it to the floor, 1 15mm water connection easy enough to take off, then it will just pull out of the toilet pan connector. When replacing may need some marley grease or lubricant for putting the toilet waste back.
Keep the cistern level with the pan, try not to twist or lift by the cistern as the seal is normally only a foam o ring and the slightest movement will cause it to leak, have you tried drain rods from soil vent ?
Posted: Sun Jun 24, 2007 4:23 pm
by OliB
Thanks, htg engineer, same problem solved in about 20 mins. Much appreciated.
