Kitchen tap
Posted: Tue Mar 06, 2007 9:14 am
by PJ
I'm looking to replace our kitchen tap (mono block mixer) with another similar one. The existing tap has copper tails and soldered to copper supply pipes. Can these be changed to flexible pipes as I wish to slightly reposition the sink in a new worktop, and can these be 'push fit' or compression fitting then? Thanks in advance.
Posted: Fri Mar 09, 2007 4:57 pm
by Cpt Nemo
Hi PJ
Yes mate - use the flexi tap connectors. They are made in a number of sizes - with push fit or compression on the 15mm end.
The most common size is a 12mm screw fitting on the tap end and a 15mm fitting on the other end.
They also make 10mm options.
If you are going to take out the tap you should invest in a set of mono-block tap spanners to get up and on the back nut(s) - trust me it'll be the best £5.00 you ever spend.
Jim
P.S You can find out more about our Weekend Plumbing courses by following the link from the bottom of every project page on this site.
Posted: Fri Mar 16, 2007 2:11 pm
by thedoctor
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE
www.diydoctor.org.uk/projects.htm
