Leaking Shower Valve
max101
by max101 » Sat Oct 23, 2010 4:36 pm
We have a Grohe shower valve and its leaking fron the bottom of the valve itself. It only leaks when the shower is running but it's quite a bit of water making the shower pressure poor.
Should I have a look inside it or do I need a plumber???
Thanks for any help.
max101
by max101 » Sun Oct 24, 2010 8:06 pm
Come on guys, someone must know what the problem is??? You always do...
plumbbob
by plumbbob » Wed Nov 03, 2010 11:08 pm
Grohe make many different types of valve so without knowing what type you have makes it difficult to be helpful without typing a book.
Grohe are good showers so this is an uncommon problem. I assume you have checked the shower hose is tight and has a washer fitted?? That is of course assuming yours has a shower hose??
It is currently Fri Jan 10, 2025 2:31 pm
