hummmming pipes plumbing
Posted: Sat Jun 16, 2007 1:45 pm
by dannym
an anyone tell me how to get rid of humming water pipes, when we use the shower after a few minutes or turn the taps on for a while I have tried bleeding the radiators,we had it last year about sept and it went away when the heating was put on hence me bleeding the radiators
here's hoping you can help
Many thanks
danny
Posted: Sun Jun 17, 2007 11:20 am
the water to the shower and wash basin etc are not connected to the radiators. The sound is probably water hammer, try turning the water flow rate down at the main stop tap and check pipes are lagged and clipped where necessary.
Posted: Sun Jun 17, 2007 11:40 am
by devilsback
is the humming happening after running the hot, cold tap or both, if its ot only, you have a f and e tank in the loft which feeds water to the hot water cylinder the washer in the float valve that fills this could require replacing
