fixing Ikea cupboards to wall
Ana Brady
by Ana Brady » Tue Feb 08, 2011 5:01 pm
WE're trying to fix Ikea Besta cupboards to an internal breezeblock wall (plastered + in good condition), cupboards measure W 120 x D 40 x H 60cm.
They come w plastic brackets which are secured between back panel and recess at the back + screw into the side panel. Then you drill through the back panel to fit your fixing through panel and bracket.
Has anyone used them and found them safe/unsafe??
ALso what screws would people recommend?
8x75mm 'thunderbolt' screws as suggested by my local DIY shop or rawlplugs w 10x100mm screws?
Thanks for any ideas
by stoneyboy » Tue Feb 08, 2011 11:09 pm
Ana Brady,
The brackets work OK but if you are joining wall units I suggest you fit a level batten under the units to make sure they all line up.
Use wood screws with wall plugs for fixing, 6x70mm should be long enough.
It is currently Fri Jan 10, 2025 8:22 pm
