hot water very slow kitchen tap
gaza
by gaza » Sun Jun 24, 2007 8:54 pm
the kitchen hot water tap is very slow running just above trickle but the bathroom taps are fine any ideas what is causeing this ,all help whould be greatful .thanks gaza
:x
by htg engineer » Tue Jun 26, 2007 8:04 pm
Could be the tap washer has broken down, or came away from the spindle. Or could just be the plastic spray cap could be blocked. The plastic cap is fitted in the tap (where the water comes out) pop it out using a screwdriver or something similar and try the tap see if its any better.
If not, turn off water and take the tap head off, there'll be a hexagonal head where it meets the tap, undo this and replace the washer and clean the tap out.
big dave
by big dave » Tue Jun 26, 2007 9:45 pm
do you have a filter on the end of your tap ? if yes unscrew it and clean it out
zion666
by zion666 » Sun Dec 02, 2007 12:04 am
MY HOT WATER TAP ON MY BATHROOM MIXER TAP HAS GOT LOW WATER PRESSURE,AND PRESSURE IS FINE ON BATH TAP WHICH IS NOT A MIXER
It is currently Tue Jan 14, 2025 1:16 pm
