water on stopcock area
3rdy
by 3rdy » Tue Jan 10, 2012 8:32 pm
I've just noticed that the stopcock on the riser main and the pipes around it are wet (no water on floor) ...there also seems to be mould growing on the pipes
the stopcock and pipes are cold....so could it just be condensation?
i keep opening the window to ventilate the utility room but the wife keeps shutting it moaning she's cold :/
plumbbob
Re: water on stopcock area
by plumbbob » Tue Jan 10, 2012 9:49 pm
You are very probably right and increasing ventilation might not improve matters much.
You could try lagging the pipe in insulation which could prevent the moist are from getting into contact with the cold pipe.
3rdy
by 3rdy » Tue Jan 10, 2012 10:01 pm
ok thanks...keeping my eye on it
3rdy
by 3rdy » Tue Jan 10, 2012 10:14 pm
i've wrapped a sock around the stopcock (which is cold to the touch) to see if the moisture stops..would that help?
i'm just a bit concerned..i have the plumbing insurance from homeserve but i've been reading some really bad reviews about them :(
3rdy
by 3rdy » Wed Jan 11, 2012 2:16 pm
turns out it was condensation :)
checked it this morning and it was dry
phew :)
It is currently Mon Jan 27, 2025 7:41 pm
