new water main
Posted: Sat Jul 07, 2007 9:33 pm
I have just fitted the Yorkshire fitting collar of a 25mm to 15mm stop tap onto my new water main MDPE 25mm pipe, slipped th e25mm olive over the pipe with it and had to ram in the black plastic insert into the end of the MDPE pipe. It is so tight now that it is impossible to turn the collar to make the connection to the stop tap!
Does anyone have any ideas what I am doing wrong?
Unless one uses the pipe inserts, I assume the olive will just chew up the MDPE pipe, but with them in it is impossible to make a connection.
