Slow draining new shower
Posted: Thu Jul 26, 2007 12:36 am
hi
i've recently had an ensuite made and a shower fitted. I was testing the shower when i noticed that the water drained very slowly.
I assumed it may have been some grout from the tiling or dust from the building work being carried out in the property. however using a plunger and trying to shift the blockage with a piece of electrical wire im not sure what the problem could be.
Im having the same problem with the new bath which has been just fitted. i would be grateful if you could help. i was thinking of using some chemicals but the shower and bath have not been used so i dont presume it could be hair or grease. cheers
