Joining two cold water tanks in the loft
Posted: Sat Jul 28, 2012 11:08 am
by philupnorth
I need to join two 25 gallon tanks in the loft for my new shower & was wondering if I need to use brass fittings to connect them together? Could I use Mcalpine compression tank fittings instead? I should use a 28mm connector according to salamander but is there any reason I couldn't use 32mm Mcalpine fittings as there would be grater flow & it would also be cheaper than using copper & brass.
Re: Joining two cold water tanks in the loft
Posted: Thu Aug 02, 2012 2:38 pm
by plumbbob
28mm is the minimum bore of pipe connecting the two tanks so the 32mm McAlpine would be alright.
Don't forget to have the ball valve feed in one tank and the outlet in the other tank. This is to ensure the water doesn't become stagnant in one tank.
