Pumped Feed to Hot Water Tank and Diameter of Pipework
Posted: Fri Dec 06, 2013 11:39 am
I am in the process of fitting radiators and pipework ready to have a boiler fitted. I have a gravity fed hot water tank which has a solar panel heating with an immersion heater for top ups in the winter and it also has two auxiliary heating coils, I wish to feed one of these coils from the boiler instead of using the immersion heater. Whilst I accept that 22mm pipes are required if heating the tank by gravity, is it ok to use 15mm from the boiler pump. The tank is probably about 5 metres from the boiler
