How to Service and Replace Cartridges in Franke Olympus S tap
Posted: Thu Nov 27, 2014 8:16 am
Having trouble dismantling a Franke Olympus 'S' tap in order to service/replace the cartridges (ceramic disc valves).
Here's the exploded diagram:
http://www.central-servicesuk.co.uk/shop/shopimages/olympus%20s-parts.jpg
I've managed to remove diagram parts #11 and #6 [grub screw and tap lever assembly], exposing the toothed end of the cartridge.
The component I'm having a problem with is #5 [the 'shroud' that surrounds the cartridge].
I've read elsewhere this part should unscrew - but mine doesn't seem to want to budge at all. It seems really stuck fast.
Can anyone confirm this part should definitely unscrew? If it should, then I suppose it must be stuck with a load of limescale that needs softening/removing with vinegar or something.
Any advice welcome.
P.S. I do have a photo but I'm not sure how to attach this to a post in this forum.
Any advice welcome.
