How to create a water tight connection to a pipe from a container
Sean9461
by Sean9461 » Fri Feb 26, 2016 10:42 pm
Hi I'm new here I'm pretty new to building things for myself and lately I'm trying to build something but with all my research I'm hitting a snag when trying to figure out how to do what I need to do or if it's even possible.
Basically what I need to be able to do is drain water from a plastic container to a pvc pipe. The container will fill up with water and I need to drain it back into a system.
How would I go about drilling a hole in the bottom and sealing the whole up with the pipe correctly so that it drains with no leaks?
Is this possible?
Thanks for any help
Fred c
Re: How to create a water tight connection to a pipe from a container
by Fred c » Sat Mar 05, 2016 9:11 am
Go to plumbing store and get a tank connector. Bring a little piece of pipe with you for correct size.
It is currently Tue Jan 07, 2025 12:05 am
